Hot tub pump blowing fuse Discussion ThreadHot tub pump blowing fuse Electrical Advice
Dont know much about motor testing but I have the following results. Pump was working fine until recently but blows fuse as soon as energised. The pump is 7amp max and was fused at 10a, glass type. I got 4 ohms between live and neutral at the pump terminals and >100 megs to earth. I have no idea other than a new pumps around 200 quid. Wiring all looks fine as does pump terminal block. Not sure what erase I can test?
Hot tub pump blowing fuse for the original thread on Electricians Forums
