Discuss how close should the space be between porclain? in the British & UK Tiling Forum area at TilersForums.com.
bocean02
Hey boys and girls, I am laying pocelain tiles on a small bathroom floor next week and was asked if I could put them flush together. I am concerned that for one it needs some sort of sealant and another, that tiles are never square enough for this to be done effectively. If this is the case should I just stick with a 2mm space and use a dark grout to match the tile??
grumpygrouter
Hi all i disagree , i have laid many porclain floors and butted the tiles up together as customers have asked.
I then grouted them with a fine wall grout same colour as the tiles just to seal the joints.
Hope this helps and good luck:thumbsup: :thumbsup:
My comment was based on the assumption that the floor is a timber based substrate as is most comment in the questiones asked on here. If so I personally would not tile without a grout line of at least 2mm and flexy grout not only because it is porcelain but because of movement in the subfloor. If it is unheated screed/concrete then that may be a different matter.
DHTiling
I do not recommend anybody to butt joint tiling.....this method does not allow for grout to fill the joints unless you slurry grout and does not give any room for tile sizing.
And also on larger area's butt jointing will increase the chance of tiles tenting and de-bonding....bs5385 recommends a 3mm joint but i think 2mm can be used .....
mz30
No offence ,but you have laid many a porcelain floor wrong,it's your job to tell the customer that the tiles should not be butted up and also you should not be using wall grout on floors.
Deleted member 1779
Just to confuse things on 600x300 porcelain tiles I asked for thicker joints of 3mm and my tiler was happy to oblige
but then I WANTED to emphasise the brick pattern so chunky 3mm was the order of the day.
Reply to how close should the space be between porclain? in the British & UK Tiling Forum area at TilersForums.com
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
Hey everyone! Just want to say first of all that I am not a tiler or anything I’m just in need...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hi there I ordered 160sqm of 90cm x 90cms of matching Large Format Porcelain tiles. 105sqm for...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
