Deleted member 1779
[h=1]How do I drill a hole in a sink? [/h] [h=1]Can you tell me how to use a diamond core or holesaw or drill bit to drill a hole into a ceramic sink[/h]
Model shown IKEA DOMSJÖ Sink bowl
Answer: At 365drills we have our own team of staff dedicated to drilling holes into ceramics and porcelains and we can come to site and do the work.
[h=1][SIZE=+1]This is how we did it[/SIZE][/h] [h=1]
[/h] Shown first and above is the actual sink we will be drilling into
First we remove the sink from its fittings. A bit messy but no matter
Now we have to remove the tap
The sink is inspected for damage and photographed
All marks are noted and photographed (Note this is just dirt not scratches)
Our method: Take a look at the hole. You can see that it is well over 30mm thick (The maximum drill depth of the core) and it also contains the drainage ring from the overflow. Its essential that this channel be maintained so that the overflow can operate. Good news the increase from 85mm to 90mm will have a minimual impact on the centre drain ring. We are only going to remove 2.5mm of material.
The plan is to secure a clamp to the shiny side of the sink (top side - inside) and to drill to the centre of the drain chanel. The clamp will then be removed. We will then continue to drill through the sink using the top ring as our drill guide. That way we do not have to turn the sink upside down and meet the hole in the middle.
| Dear 365-Drills, I have a ceramic sink that I bought from IKEA and I wanted to fit a waste disposal unit instead of a standard waste trap. The problem is that the hole is too narrow. Its 85mm and it needs to be 90mm. How do I drill a hole into a sink. How to I widen the hole into the sink so that the WDU fits. The whole kitchen has been built around the sink so its difficult to change the unit. |
