How do I wire a 3-way Zooz Zen21 smart switch? Discussion ThreadHow do I wire a 3-way Zooz Zen21 smart switch? Electrical Advice
The following dead-end 3-way wiring diagram shows my current setup with the Zooz Zen21, but it's not working. This wiring works fine with a simple standard paddle 3-way switch that doesn't require a neutral wire. However, since the Zooz switch requires a neutral wire, I ran a white wire from the capped neutral wire from the breaker and the light switch to the neutral slot in the Zooz, but it didn't work. Is there another way to get the Zooz switch to work? Thank you in advance.
How do I wire a 3-way Zooz Zen21 smart switch? for the original thread on Electricians Forums
