Discuss How Long in the UK Tiling Forum area at TilersForums.com.
T & P
Help please I have got a bathroom to tile floor to ceiling 17 sq.metres plain ceramics 200mm x 250mm with chrome edging running all round the room. Plus the floor which is only 3sq metres. I am removing the toilet, washbasin and radiator before tiling when replacing. I'm boarding the floor with ply and tiling the floor again with ceramics. How long would it take you experienced tilers to do the job? Thanks
T & P
Personally,
2 full days to do the walls.
Is the floor already tiled and to be taken up. If so I would allow full day to take up, reboard and tile.
The rad pipes are probably going to need moving unless you have enough give on if poly pipe.
And 1/2 day to reinstall toilet, washbasin and radiator
Thanks Elliot
I do not have to remove any floor tiles and I am not removing radiator brackets (tiling around) so that I do not have move radiator pipes.
guy1976
if you are boardind floor then putting tiles on top then putting sink and toilet back in you may find that the pipes dont reach so you may have to replace with flexi hoses also with the rise in floor the toilet and sink wastes might not line up so for the toilet you might need to buy a off set pan conector for toilet waste and a extra length of waste pipe for sink which there is 2 sizes so measure first if you need it
Reply to How Long in the UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hi everyone! we have this beautiful porcelain floor down - there's 25 square metres of it. It...
Hi, a long time since I have been here but back for some advice/reassurance ! About to tile my...
Total newbie to tiling. How flat is flat with regards to a floor? I have a small downstairs...
ben209384234
How Long
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
