tysfoot
Hi, how much experience would you need to go for an nvq in tiling then, ive heard they can esses you on domestic jobs, is this true
Discuss How Much Experience Required For An NVQ2? in the British & UK Tiling Forum area at TilersForums.com.
The minimum requirement for an NVQ2 in Tiling through OSAT is 3 years.Hi, how much experience would you need to go for an nvq in tiling then, ive heard they can esses you on domestic jobs, is this true
Do you work for yourself or a tiling school / college?Yes this is true, im a tiling assesor and it all depends on how much experience you have.
Surface prep means either remedial plaster work, screeding, SLC, reboarding, patch and repair etc.on the nvq it says surface prep is part of it, does it just mean levelling floors with slc or does it mean plastering etc.
what does it actually want.
any one actually have a proper description of what is wanted in each segment.
cheers
Basically making the surface good - wall or floor - ready to accept tiles.
If you go onto the Skills For Business site and browse 'National Occupational Standards', it will describe to you each unit of the NVQ2 in tiling (as well as all other NVQ quals if you wish!!), so that you know what standard you need to be at for the award.
http://www.ukstandards.org/Find_Occupational_Standards.aspx
Look for 'skilled trades', then 'Building'. Then use the search filter to look for what you need.
Happy Reading!
Chase Tiling Academy
Tiling is here also http://www.ukstandards.org/Admin/DB/0012/O12NVR142.pdf
Reply to How Much Experience Required For An NVQ2? in the British & UK Tiling Forum area at TilersForums.com
