Rob1980
Hi all, I know questions regarding wooden type floors has been asked many times on many forums, as Ive been reading.
However, I feel I need to ask the question specific to my own project to feel confident I'm doing the right thing.
I'll try to keep it short and to the point but hopefully provide enough info.
I'm building an extension on my 1950s bungalow, the new flooring is a concrete finish, with a height lower than that of the existing floor allowing for 100mm joists and 18mm floorboards.
So my basic question is how to build the floor in the bathroom..
The joists are long enough so that there will be no joins, noggins will be in place, they are c16 treated 4x2, (100x50) sat directly on the concrete, or at the most, raised slightly in places but remaining supported if the concrete floor is slightly out in that room anywhere (the other rooms have been pretty good so far).
I think you use the term deflection, am I right in thinking this would be close to, if not zero, as in no movement?
joists will be 400mm centres.
Should I put a single 18mm board onto the joists or use two layers to build up to 18mm?
What material should I use, please bare in mind, the cheaper the better, but of course I'm here asking to get a product that will suit tiles, so I understand its going to cost more than chipboard.
I think that covers it.
Rob
Rob
