Discuss How should I remove adhesive from porcelain tiles in the British & UK Tiling Forum area at TilersForums.com.
gusit
Hi Folks,
I have just tile a bath and sink surround with porcelain, slate effect tiles and have managed to get some of the adhesive on the front which isn't scrubbing off very easily :mad2: . Can anyone recommend what the best stuff to use is (is one of the Lithofin range the best?) and what sealer I should use when I come to do the same in a shower enclosure (to give a slightly gloss finish)?
Cheers
Angus
GazTech
Hi Folks,
Cheers
Angus
Lithofin cement away will do the job....regards a satin finish for your tiles try Fila colour intensifier.....Gaz
DHTiling
KF Ceramic Clean - 1L
For the removal of light cement film, lime-scale, soap residues, grease and rust from ceramic tiles, tumbled
marble, porcelain, chromium and sanitary fittings ... not really want you need...
I would recommend the lithofin cement away as well....
Cement-Away - 1L
A very strong acid for the removal of stubborn cement residue, efflorescence and heavy builders dirt. For newly laid and older non-acid sensitive tiles such as porcelain, ceramic, quarry, terracotta, slate and sandstone tiles
wetdec
There are a couple of black slate look porcelain tiles on the market with a shine on them making them glisten in the light. RAK made then, creta coppied them and collinson have their own.
If you grout these without cleaning off immediately they will stain and you will be left with a cloud.
They look pretty but are ******* to fix.
I know its a bit late but might help others.
tiler
gusit
Thanks for the advice guys. I did pre-seal them (after sticking them up but before grouting and then worked on getting the grout off immediately. It seemed to work well and they look pretty good now but getting the adhesive off them was a ***** - luckily not one which left any staining!!
One question, is there any reason not to seal them before you stick them up or is that a bad idea (or just a pain!)?
Cheers
Angus
sweetpea0902
Hi, Im just after having 60x60 cream porcelain tiles laid in my kitchen and today had my new kitchen installed...problem, on cleaning up after the guys I notice that 2 or 3 tiles have stain on them and am finding it difficullt to remove. it looks like tea or coffee stain but I think its actually a residue of some substance they used. I hadnt actually got around to sealing them before kitchen installed. Any suggestions please?:huh2: Sweetpea
Reply to How should I remove adhesive from porcelain tiles in the British & UK Tiling Forum area at TilersForums.com
The saga of my hollow floor 50sqm continues. All tiles now lifted but there is adhesive around...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
