Discuss How to calculate tiles required for Floors with borders in the Canada Tile Advice area at TilersForums.com.
baht'at
Hi all.
Went to price up for a bathroom this evening and as about to leave the customer asked if could also give a price to tile the Hall way and once I had measured up she then showed me the attached picture and said she would quiet like it to look like the photo.
Can any one give advise please regarding how to or point in the right direction for information regarding how you start to work out how many of the different tile you would need to be able to reproduce a floor similar to the attached.
Does any one know of any sites that also give guidance on how to set out and lay tiles like this one
All sensible advice appreciated.
baht'at
Thanks for the responses.
Firstly i was only trying to find how to work out quantities so they then could go and get an idea on what it was likely to cost just for the tiles.
Secondly I am not afraid to say No to a job if beyond my capacities but we have all wanted to or have tried to lean some thing new. All I am trying to find out just how complex some thing would be to do.
Even those who specialise in this type of flooring had to start some where.
Bill
It is easy....just template the floor with lines or a CAD computing program.
Note how many internal/external (or you could be lucky so that they reverse - these look like square tiles with a pattern on so this would be easy to calculate) angles there are, then use your field tile to determine the extent of the field pattern so that gives you the perimeter of the outside border tile. The tile to the wall is a filler tile.... this can be used to help keep the border and field tile looking as symmetrical as poss.
MTiler
True but they wouldve started small, learn to walk before you can run.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Just out of interest what kinda shape is her floor? Because that one looks like a magazine type photo shoot to show the tile. Seems quite evenly spaced for that tile size etc. Your actual fooor probably isn't. And that makes it a bit of a minefield.
Checkout the Victoria floor tiling category (Victorian Floor Tiles - http://www.tilersforums.com/media/categories/victorian-floor-tiles.6/ )and you will see some of timeless johns and Phil Hobson's floors. And pics part done. I wouldn't contemplate it unless I was doing my own floor so I could risk bodging it.
Reply to How to calculate tiles required for Floors with borders in the Canada Tile Advice area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
