Discuss How to cover/work round copper pipes? in the Canada Tile Advice area at TilersForums.com.
Hi All,
Installing Marmox boards in a shower area and want to avoid a stud wall to keep as much space as poss.
Will carry on with dot and dab (uneven old walls) for the boards but what advice could you give for where the shower pipes are?
If i was to cover them then the boards would sit out maybe 20-25mm, could i go flush against the side of them and protect then skim over the pipes somehow?
Cheers
I would’ve chased them in. Keep in mind that any cement that comes into contact with the copper will attack it. Cover it with Duct tape.
If you do board either side and skim the pipes with something then make sure the pipes are still buried by a decent amount otherwise the skim will crack on the hot side due to expansion/contraction which potentially can come through to the tiles/grout. Usually you’d use a pipe scrim or felt.
Yeh unfortunately i think it might be too late to chase them, bit of a change of decision in the end but I'll see how far out the board could sit and felt insulate the hot side? Also protect the copper too just incase. Thanks
Reply to How to cover/work round copper pipes? in the Canada Tile Advice area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Hello, this is my first post so here goes, advice needed. It was decided that I should renovate...
My mum is having her bathroom fitted and she sent me some photos and my partner pointed out that...
5K
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Galashiels
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
