Discuss How to fix items to a hardibacker board wall in the UK Tiling Forum area at TilersForums.com.
shneld
Hello everyone.
I have a timber stud wall with hardibacker board and 10mm thick porcelain tiles.
I need to fix a shower rail and other various small items to this wall.
What is the best method of fixings items to this?
I was thinking using the metal plaster board fixings, the ones with the wings that grip that back of the board as you screw the screw. I would also flatten off the little spikes that grip into the face of the plaster board as it will be tiles.
Can anyone suggest a better method?
Many Thanks
Lee
shneld
hi,i would pad the wall before fixing the boards over in the areas needed or have you already tiled
Already tiled :(
if you've already tiled, drill a bigger hole than the plug through the tile, then drill the backerboard for your plasterboard plug,then plug the backer board. that way you won't be hanging anything off the tiles
I think this is the option I will take
Best way was to set out fixings before you boarded and put timber noggins/studs in the right place,, but as you seem to be tiled up then Mike has the right idea...
Lesson learnt :) ill do this next time.
The holes needed to get the butterfly fixings through are usually quite big, if its 12mm hardie you should be able to screw straight into it as you would with wood and get a firm fixing - i'm sure thats how i've done it in the past - its been a while.
Really, it is 12mm hardibacker. Its tempting to just screw into it as you say but for peice of mind I may use plasterboard fixings.
If you had known where the fixings were going beforehand you could have fixed an extra peice of stud work to allow for weight issues.
Im going to do this next time.
Thats is one thing I did was ensure there is plenty of noggings in (unfortunatley not where the shower head rail is going lo ) to support the wieght, the tiles are 300x600x10mm!
Do we recon just screwing into the 12mm hardibacker will suffice? Its a shower head rail that needs fitting, just your usual plain simple shower head rail/riser.
Thanks for your help everyone.
Reply to How to fix items to a hardibacker board wall in the UK Tiling Forum area at TilersForums.com
Bathroom being refurbished. A load of things have been rushed like some loosely rollered (not...
I'm hoping someone here can give me some advice! I'm re-tiling my shower after needing to rip...
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
TF Group Please Join
Tilers Forums on FB
