Guest viewing is limited
Discuss How to tile a fibreglass balcony? in the UK Tiling Forum area at TilersForums.com.
F
FreeD
Went to look at a job today...external fibre glass flat roof, ceramic 30x30 tiles have completely delaminated from surface, grout all cracked and missing...no adhesive stuck to the fibreglass all peeled off with ease.
How would you recommend re tiling this to prevent the same happening? Bal tech recommended fast flex. Mapei recommendeds keralastic epoxy adhesive.
The roof is recieving a high amount of water from 2 downpipes coming from a conservatory above it...(i'm think of re routing these away from the surface) there is slight deflection.
Total area 17m2, I'm also wondering if I'll need expansion joints.
F
FreeD
To be honest the bumps arn't that bad...but the surface is certainly not flat...but I will tell the customer that I will go with the existing levels...I didn't check the fall but it certainly looked and felt like the whole surface fell towards the guttering at the end of the roof as it should.
Do you reckon that will be ok to membrane maybe just level it out slightly with adhesive in places?
Maybe I should give the customer the option with or without membrane?
Reply to How to tile a fibreglass balcony? in the UK Tiling Forum area at TilersForums.com
Bathroom being refurbished. A load of things have been rushed like some loosely rollered (not...
