Discuss How to work out a brick pattern in the Canada Tile Advice area at TilersForums.com.
Mistyscamp
Hello all, just trying to work out how to lay out my tiles, in the bathroom, in a brick pattern. I have 2 walls that are 166cm wide, 1 wall 104cm wide and 1 wall that is 179cm wide, the height is 231cm and the tiles that I am using are 25 x 20cm. I can see that the 2 walls that are 166cm will take 6 tiles plus a tile of 15cm so giving me a base to work with but the other 2 walls are causing me problems. Any help would be much appreciated.
charlie1
Hello all, just trying to work out how to lay out my tiles, in the bathroom, in a brick pattern. I have 2 walls that are 166cm wide, 1 wall 104cm wide and 1 wall that is 179cm wide, the height is 231cm and the tiles that I am ousing are 25 x 20cm. I can see that the 2 walls that are 166cm will take 6 tiles plus a tile of 15cm so giving me a base to work with but the other 2 walls are causing me problems. Any help would be much appreciated.
See when you cut the tile at the end of wall 1, use the cut off for the start of wall 2.
Reply to How to work out a brick pattern in the Canada Tile Advice area at TilersForums.com
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
Hello, this is my first post so here goes, advice needed. It was decided that I should renovate...
Tilers Forums on FB
