Discuss How would this be boarded? in the America Tile Forum / Advice Board area at TilersForums.com.
Grazza
Kent
Hi,
Any ideas how I would attach a foam backer board (or indeed any type of backer) along the right side of the window in the attached picture.
The right side is about 130 mm.
Grazza
Kent
Is this a joke?
Mechanically fix; screws for cement boards, screws and big washers for foam XPS boards.
Why do you think its a a joke? What do you think this forum is for? LOL
That section is just 130mm wide. Ideally I would put a screw in the left and the right hand side because just a single screw in the middle would potentially pivot.
Apparently I dont need adhesive if its an even surface, but obviously the adhesive would prevent any movement.
The down side with putting a left and right fixing is that its really close to the window reveal and as Im sure you know you cannot drive to close to the edge else the block will split off. esp with spanker dowels.
Im also wondering if there is reason for using 1200 hardies over 2400 foam backer? So sorry Ben if that question isnt valid enough for you. Maybe someone else has some less negative advice?
46
478
Dorset
I’m messing with you pal!
As you say adhesive not needed but if fixings are poor it’ll help you out.
I’d put screws down both edges to stop it rocking.
Drill a couple of test holes if you like to see how plugs hold- if suspect just stick it on , then when dry a couple of mechanical fixings gently in the centre will be fine and stop it ‘peeling’ - much as one does when dot/dab plasterboard.
Reply to How would this be boarded? in the America Tile Forum / Advice Board area at TilersForums.com
HI, we are redoing our bathroom and looking for a second opinion. We are having an issue with...
Hi, I've just seen patches of tile backer board with patches where something looks to have...
Morning guys and gals My grandma had this hanging in her kitchen for as long as I can remember...
USA Tile Forum Popular
America Tile Advice Trending
Kent
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
