• Thread starter Al@Lifetiles
  • Start date
  • Replies 15
  • Views 308
  • Tags
    usa
Discuss Hydrated Lime. in the UK Tiling Forum area at TilersForums.com.
Al@Lifetiles
Hello All. Got a grade 2 listed job coming up. Part of it involves replacing some original quarry tiles in what will be there utility room.
The original tiles were apparently laid straight onto a chalk/Lime substrate and over the years movement has created gentle undulations in the floor! Architect wants them replaced as original as possible and has asked for a hydrated lime/ sand mix to bed the tiles on.
Anyone ever come across this before?
All help appreciated as i havnt the foggiest.
Pebbs
Here you go,
After much debate (some heated I'll come to that in a minute), this is how we do it.
4 parts sharp sand
1 part hydrolic Lime
Approx 3% white cement (we put this in to ensure some solidity in the bedding)
Mix the sharp sand and the lime and the white cement to a semi dry mix and bed down hard. Then sprinkle over with water from the watering can.
The important bit is this, make sure the back of the stone has been covered with wet lime slurry or you won't get the adhesion to the bedding.
Ensure that the bed is solid, and the stone is well bedded, if you dont your going to know about it a few months down the line.
Also an important factor is the temp, it is notoriously difficult to get it to set off in cold weather,
I have to throw this in, you said the architect is stated hydrated lime, well unless you have 6 months to sit around waiting for the bedding mix to go off then its all good, but you havent. You need to clear this with them and get this point across. Hydrated = no Hydrolic =yes?
Let us know how you get on.
Lynn
Al@Lifetiles
Thankyou for taking the time and sharing your knowledge!
I will speak to builder in charge tomorrow and query the hydrated/hydrolic thing. It could simply be me mis-hearing him on the phone.
I did speak to one other builder i know and trust and he also said to add a bit of cement in the mix for solidity so this compounds what i have to do.
Thanks again and pictures to follow.
White Room
Here you go,
4 parts sharp sand
Lynn
If your putting cement with hydraulic lime then why not use just sand/cement....which hydraulic lime would use 3.5, 5 or above.
Al@Lifetiles
This is why i have posted on this forum! Is there a definitive answer that i can go to the architect with?
Probably not. The issue is adding cement. Without it i cant see the floor ever setting or being solid enough. With it will upset the men with clipboards.
This is also only my view, but i know alot more than i did 24hrs ago.
Reply to Hydrated Lime. in the UK Tiling Forum area at TilersForums.com
Hi there I’m new to Tile Forum and joined to get professional opinions because I really need...
I had my bathroom done in September and my floor tiles have movement in them and the grout is...
I would like some advice from experienced tilers on this forum. Had a vertical crack across a a...
Hydrated Lime.
Tags
usa
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
