Discuss Identification in the British & UK Tiling Forum area at TilersForums.com.
CUSH68
Hi all,
Looking for best way to identify tile material. Went to quote for bathroom tonight and customer had collected loads of tile samples without bothering too much about what they were made of!
Some more easily identified than others. Is there any quick test to categorise say porcelain from ceramic of similar sizes etc?
Cheers,
Mark
wetdec
Porcelain, wet the back doesnt absorb very much, it will be heavier than a ceramic tile, generally has grid mark on the back, predominantly rectified.
Ceramic, wet back sucks it up, quite light, edges rounded over, generally brown or white biscuit
sizes just use a tape there is no shame in that you cant be expected to know all the sizes
Hope this helps you a bit
tiler
CLAYS TILES
tiler
even simple way, it says porcelain on back of tile!
grumpygrouter
Hold tile at a corner between thumb and fore finger and flick the tile with the other hand. If it produces a ringing sound as opposed to a dull thud it is porcelain. The back of a ceramic is a biscuit colour with a patterned front, a porcelain is the same colour throughout.
They can be glazed and have a different colour glaze!
Grumpy
CUSH68
RIGHT SO PORCELAIN MAY OR MAY NOT SAY PORCELAIN ON THE BACK BUT IF IT DOESNT THEN IT MIGHT BE CERAMIC IF ITS NOT PORCELENATO, UNLESS IT SAYS THAT ON THE BACK. AND PORCELAIN IS THE SAME COLOUR RIGHT THROUGH UNLESS ITS GLAZED THEN IT MAY LOOK LIKE A CERAMIC.
THAT CLEARS THAT UP THEN!:whatchutalkingabout
CUSTOMER DECIDED WHICH TILE SHE WANTED AND TURNS OUT IT WAS GLAZED PORCELAIN (UNMARKED ON BACK).DID THE WATER TEST, PING TEST AND PHONED SUPPLIER WHEN I GOT HOME.:grin:
CHEERS,
MARK
CLAYS TILES
if it breaks ya finger its porcelain:yes:
Reply to Identification in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
Hello all. We have employed a tiler to do our bathroom and floor tiles. We bought the tiles...
5K
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Identification
Tags
usa
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
