Discuss if customer has already prepped in the British & UK Tiling Forum area at TilersForums.com.
F
Fekin
what's ettringite then dave? he he he!!:lol:
Ettringite is a hexacalcium aluminate trisulfate hydrate, (CaO)6(Al2O3)(SO3)3 · 32 H2O.
Ettringite is found in hydrated Portland cement system as a result of the reaction of calcium aluminate with calcium sulfate, both present in Portland cement. [1] Ettringite the more prominent representative of AFt phases or (Al2O3-Fe2O3-tri)) can also be synthesized in the laboratory by reacting stoichiometric amounts of calcium, aluminium and sulfate in water. In the cement system, the presence of ettringite depends on the ratio of calcium sulfate to aluminate; when this ratio is low, ettringite forms during early hydration and then converts to the calcium aluminate monosulfate (AFm phase or (Al2O3-Fe2O3-mono)). When the ratio is intermediate, only a portion of the ettringite converts to AFm and both can coexist, while ettringite is unlikely to convert to AFm at high ratios.
The chemical formula used by cement scientists is C6AS3H32;
The characters designate standard notations: [2]
C = CaO,
S = SiO2,
A = Al2O3,
F = Fe2O3,
S = SO3,
H = H2O,
K = K2O,
N = Na2O,
m = mono,
t = tri.
Apparently :huh2:
DHTiling
C = CaO,
S = SiO2,
A = Al2O3,
F = Fe2O3,
S = SO3,
H = H2O,
K = K2O,
N = Na2O,
m = mono,
t = tri.
Reply to if customer has already prepped in the British & UK Tiling Forum area at TilersForums.com
What would you guys do with the walls to prep for fitting 1200mm x 600mm Onice Verde (Porcelain)...
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
