Discuss Immersion fuse or MCB? Electrical Advice in the Electrical Advice area at TilersForums.com.
Immersion fuse or MCB? Discussion ThreadImmersion fuse or MCB? Electrical Advice
An immersion heater 3kW, say off a final ring. A number of points.
Is is best have a 13A double pole FCU switch or a double pole 13A type C MCB?
A fuse is one-shot. If it blows the danger is eliminated until seen to. The MCB in a local enclosure doubles as switch but can be switched back on by the user.
Gradual current increase on a 13A fuse can cook a 2.5mm cable before a fuse blows. This can be a dangerous yet all legal. This is not such a problem with an MCB which will trip quicker.
Any views on this welcome.
Immersion fuse or MCB? for the original thread on Electricians Forums
Reply to Immersion fuse or MCB? Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
