ojtiler
All,
This isn't a query, just a brief summary of a situation I got myself into which you might want to avoid! In my wetroom project, I bought the tanking membrane right at the start of the job - I selected the Impey membrane as it looked relatively easy to install.
To avoid having to re-grout my wetroom in a few years, I decided to go for Epoxy grout, to make an exceptionally durable (and waterproof) finish between the tiles.
The thing I overlooked was that, as well as the Impey membrane being incompatible with silicones etc, Impey also recommend that epoxy grouts should not be used!!!!
Having taken technical advice from both Impey and BAL (the manufacturer of the epoxy grout), the solution I have implemented is to ensure that the epoxy does not actually directly contact the membrane. On the floor I am using SLC, so there is a nice 4-5mm protective layer over the membrane in that region... On the walls, I am ensuring I get a solid bed adhesive layer behind the tiles and will also put a layer of normal (cementitious) grout on the joints first (about 4mm thick), before grouting over again with the Easy poxy.
A lot of work, but the only way I feel happy that the membrane is going to be in safe.!
I think if I had my time again I would go for a different mambrane!!
Just thought I would post my experience here, in case anyone is considering going the same way.
