merlecollins
Just thought I'd post a few pics of what I've been up to today in case anybody else has this problem
I'm doing a job where the builder had fitted the Impey tray flush with the wayrock (chipboard) flooring:mad2:
Obviously I'm not going to tile the wayrock, so had installed Hardie backerboard over this and stopped at the edge of the tray
This left me with an 8mm step up in height from the surface of the tray to the top of the HBB
To get over this I cleaned the joint between the tray and the wayrock thoroughly with my fein, then completely sealed the junction with neutral curing sealant. Once the sealant was dry I then installed a 150mm strip of RIW Tilesafe to the perimeter of the tray (adhered in accordance with the RIW installation leaflet)
This strip of Tilesafe was to act as a suitable base to screed up from
I then feathered down from the surface of the HBB to the edge of the strip of Tilesafe with Porcelflex SPF tile adhesive.
Once this is dry tomorrow, I will completely tank over the whole tray and onto the HBB
Height problem solved:smilewinkgrin:
