Discuss Inconsistent grout colour in the Australia Tiling Forum area at TilersForums.com.
jobdone
543
Chobham
Recently tiled a bathroom 500 x 200 ceramic tiles onto drylined and tanked walls(Ardex tanking). The adhesive used was webber spf rapid set. The problem is the grout colour is very inconsistent. The grout used was Ardex slate grey FS 3mm joint. the grout is almost black in some areas and very light grey with in a few hundred mm. The walls have been allowed to cure and have been washed down twice with Lithofin cement residue remover.
The effervescence has been removed but the problem persists.
Ardex have not been much help and i am at a loss as how to rectify the problem and appease my customer.
Any advise or suggestions will be gratefully recieved.
Many thanks in advance
Lithofin BOB
518
Hampshire
Did you use stated water to powder, if not the powder may have not hydrated correctly leaving areas of darker patches, or if you over watered this can also leave patches and efflorescence , test the grout stain as this can often darken all the grout and the patches ,so can still stand out as it darkens them to. ( worth a try)The acidic cleaner may not touch these as the can be the often the depth of the grout and will not simply clean away.
Reply to Inconsistent grout colour in the Australia Tiling Forum area at TilersForums.com
Hi - any advice would be gratefully received. The colour of the grout in my bathroom varies...
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
I've completed some matt white subway tiling in my bathroom and have started to do some of the...
10K
Dumbo
jobdone
Chobham
Business Name
MPT Bathrooms and tilling
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
