inspection panels in baths...
  • Thread starter Thread starter elliesdad224
  • Start date Start date
  • Tags Tags
    usa
ok,ok...... it seems that the concesus of Have recentlyopinion is in favour of tiling panels ! I got to agree that a removable panel is fine. The problems come when the entire panel has to be removable. supporting framework has got to be substantial to counteract the tendency of plywood to bow. Last panel I used Wedi board...may have found the solution........
Any cement based backerboard is perfect for this type of job,the 6mm type is easy to install and cut and very stable....Gaz
Are you remodeling your bathroom or kitchen? If so, chances are you'll need a moisture and mold resistant substitute for drywall, or a backerboard for your tile applications. You can trust HardieBacker™ Cement Board as your solution for wet area floors, walls, ceilings, and countertops because your home is your most important investment. Although no system is mold proof, HardieBacker™ board with exclusive Moldblock™ Technology delivers the ultimate in mold resistance, passing both industry mold tests with a perfect score. Whether you're hiring an installer to do remodeling work or buying a new home, be sure to ask for HardieBacker™ board by name. There are a number of alternatives on the market, but only HardieBacker™ board provides the greatest flexural and compressive strength available, while offering Moldblock Technology. You can rest assured that when choosing HardieBacker™ board, you’re taking a proactive role in preventing mold growth and moisture damage before it starts. HardieBacker™ 1/4'' Cement Board, with EZ Grid® Technology
HardieBacker™ 1/4'' Cement Board, with EZ Grid® Technology, for floors and countertops is America´s best selling 1/4'' board. It's the solution you can trust for your wet area floors, walls, ceilings, and countertops. This no-mesh board is the lightest cement board available and cuts easily, even in tight, awkward spaces,including bath panels.
I have used Lux and Wedi board. Has Hardibacker got the same cross section and construction ,or is it something completely different ?
Hardie is very similar to the old asbestolux...but obviously no asbestos..unlike the others it has no insulation wafered,it is purely cement board...totally waterproof ....Gaz
Came across a sheet of cementious board once...it was HEAVY,bowed and would not flex. I assume that this description does not apply to hardibacker?
