F
freckvan1
I'm renovating a failed Shower in an alcove. Three sides, two brick one studded.
I've just replaced floorboarding and intend installing a 60,mm slimline shower tray 760,mm.
I will be using Aquapanel as I'm having to take off all existing Plaster and Tiles.
Can someone advise me on what size battens are best to use on the brick walls and will I need to use 12,5mm Aquapanel or can I get away with 6,mm as I've seen advertised on here? Knauf recommend 40,mm screws ?
I'm using Aquapanel as the walls were all over the place, just like myself when I started!!
Thanks,
Chris
Thanks,
Chris
