Installing emergency lighting inside coach works Discussion ThreadInstalling emergency lighting inside coach works Electrical Advice
Hi all,
Just wanted a bit of advice in regards to a small installation of emergency lighting.
I have a fairly long warehouse that needs some cables run around in order to install some lighting. My question is, is it ok to run FP200 cables on / inside the horizontal girts as it’s the most tempting option.
The walls are thin metal and any fixings will have the screws coming through the other side. I have run cables inside girt’s before but just wondered if there was a better way?
Thanks!
Installing emergency lighting inside coach works for the original thread on Electricians Forums
Hi all,
Thanks!
