ceekay
Hi All
Sorry to drive you mad but I see some of you have used hardie backer boards before and I was getting some conflicting info and was hoping you could advise?
I have 3 different surfaces in an ensuite which consist of concrete block, exterior house brick and stud work. I have seen conflicting information on what board to use and how to fix it. The latest info seems to be to glue and plug and screw the brickwork and obviously just screw into the timber using 12mm hardie boards with galvanised screws? If so what contact adhesive would I use? I was thinking of grip fill or pink grip but not sure if it will adhere to the wall and the board?
Any advise would be greatly appreciated.
Thanks, Keith
Thanks, Keith
