MB2603
Hi All,
First time poster and tiler here. Hoping to get a bit of advice on tiling a wet room shower tray using hexagonal mosaic (30cm x 30cm sheets - individual tiles are probably 2.5cm x 2.5cm or so). The shower tray is level to the floor, I've used cement board on the walls and floor and tanked and taped the whole place. I've dry-layed and cut all the mosaic that I need and ready to go. The issue I am having is that I am using a nassboard tray (Wetroom Shower Tray Kit Aqua Tanking Kit - Nassboards - https://nassboards.co.uk/product/wetroom-shower-tray-kit-aqua-tanking-kit/) and it has a 15mm upstand around the drain and the mosaic tiles themselves are only 4mm high. Based on my significant levels of google research, I should only be using the V-notch trowel for mosaic so it doesn't leave me with much height on the adhesive. Net result is, the tiles are sitting below the top of the drain which is bad news.
Any advice on how I could counteract this with adhesive? I have seen some examples of using a 10mm or 12mm notch trowel and slightly flattening out the top of the adhesive and laying the tile on that. Would that work or be something that would be recommended? Any other suggestions (outside of call a professional!) would be much appreciated.
Thanks very much!
Thanks very much!
