Discuss Insulation Resistance Electrical Advice in the Electrical Advice area at TilersForums.com.
Insulation Resistance Discussion ThreadInsulation Resistance Electrical Advice
As an adult learner I understand that any equipment connected to a circuit that may be damaged by the IR test voltage should be disconnected. I watched an electrician carry out an EICR on a property I rent. On a ring final circuit he removed the plugs fom the sockets before carrying out the tests. If the socket is switched off why does he need to remove it? Thanks in advance.
Insulation Resistance for the original thread on Electricians Forums
Reply to Insulation Resistance Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
