V
VeeFourTee
An excellent forum with great advice, and I'm in need of some of the latter please.
I've built myself a bath surround using 2x2 for the frame and 12mm ply for the panels (x2), but my tiles are too thick, when attached to the ply, to sit flush under the edge of the bath. I'm tight for room and don't want to build a frame which incorporates a horizontal tiled 'shelf' around the bath. Therefore, I need to reduce the thickness of the panel onto which I'll tile.
Is a 6mm Hardi/Wedi-backer board strong enough to replace the 12mm ply used previously? I don't particularly want to use 6mm ply. My tiles are 315 x 451 x 10 ceramic, and the largest panel will need 6.5 tiles in total. I plan to tile onto the panel flat and then fit to the 2 x 2 frame.
Any assurance/advice much appreciated.
