muymalestado
Hello to all.
Where we have a good flat and sound suspended wood plank floor in the bathroom we are advised by carpet/lino/tile shops that UFH insulation boards are not required if the mode of use is intermittent, ie, once per evening.
Laminate planks will be the top surface flooring lying on the UFH. It is planned to lay a reflective sheet below the UFH with no other layers installed.
Does this sound reasonable?
Thank you.
Thank you.
