Discuss Is the tray to close to the door????? in the UK Tiling Forum area at TilersForums.com.
I'm doing a wet room, where the edge of the tray is only 260mm from the door. I said its to close to the door not to have a shower screen, I have even tried too source one for the customer. Now the job as started, they tell me, there wont be a screen, but want a gaurantee that the water wont go out the door. Is the tray too close to the door not too have a screen??
Rizzle from the Portizzle
i would give them a gaurantee that water wont go out the door as long as they dont turn on the water.the best you can do is put in a raised threshold piece under the door about 10 -15 mm higher than the tiles .if you mirte the front and back edge of the threshold piece to meet the tile it should take the step out i would normaly do this with a 40mm wide 20mm deep piece of stone leaving the centre flat 20mm then a 10mm mirte down to the tiles and door entrance
Reply to Is the tray to close to the door????? in the UK Tiling Forum area at TilersForums.com
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
  • Sticky
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Poynton, cheshire
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
