Discuss Is this 70s wiring the equivalent of 4mm T&E Electrical Advice in the Electrical Advice area at TilersForums.com.
Is this 70s wiring the equivalent of 4mm T&E Discussion ThreadIs this 70s wiring the equivalent of 4mm T&E Electrical Advice
Hi all,
I've been doing some mapping of the wiring in this property I recently purchased, the cabling for the main living and bedrooms appears to be a radial circuit (see plan, starts at the green dot, red obviously sockets and purple is the wiring). This circuit connects to a 32amp circuit breaker, and I presume it was laid in the 70s/80s. From what I understand 4mm T&E cables are required for a 32amp radial circuit. I wondered whether the cabling used is suitable for this, it measures about 11mm wide and the wires are solid core, I don't have a tool to measure this wire but see attached photo.
I would be grateful for any advise on this, also does the wiring layout look okay or would a full rewire be sensible?
[ElectriciansForums.net] Is this 70s wiring the equivalent of 4mm T&E
Is this 70s wiring the equivalent of 4mm T&E for the original thread on Electricians Forums
Reply to Is this 70s wiring the equivalent of 4mm T&E Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
