Discuss Is This Installation Wired Correctly? Electrical Advice in the Electrical Advice area at TilersForums.com.
Is This Installation Wired Correctly? Discussion ThreadIs This Installation Wired Correctly? Electrical Advice
Hi all,
I wondered if you could give us your thoughts on our friend's installation? I've included some photos. We're sure that there's something wrong with it, but we wanted some expert opinions.
Here's a bit of background:
An electrician changed the original split distribution board and carried out an EICR. Prior to the CU change, the upstairs and downstairs lighting was on two separate circuits and apparently, the lightbulbs would often blow. That's not the case now. The tariff is just on a flat rate, so our friend doesn't benefit from lower tariff through the night.
Can you tell us if all looks correct here?
[ElectriciansForums.net] Is This Installation Wired Correctly?
Is This Installation Wired Correctly? for the original thread on Electricians Forums
Reply to Is This Installation Wired Correctly? Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
