Discuss Isomat UK: Examples of adhesives available in the Tile Adhesive and Grout Advice area at TilersForums.com.
I
ISOMAT UK
Below are a few examples of the adhesives we supply with links to their technical data sheets.
High-performance, flexible, polymer-modified adhesive for ceramic and porcelain tiles on critical substrates. It is characterised by extended open time, no vertical slip and flexibility. Also suitable for fixing natural stone and decorative bricks, on concrete, screeds etc. Recommended for substrates like old tile layers, floors with in-floor heating, swimming pools etc. For indoor and outdoor applications, on walls and floors. It is classified as C2 TE S1 adhesive, according to EN 12004 and EN 12002.
Data sheet click link
High-performance, flexible, polymer-modified adhesive for fixing all types of tiles on deformable substrates. It is characterised by extended open time, no vertical slip and high flexibility. Also suitable for fixing tiles on concrete, screeds, gypsum board, old tile layers, floors with in-floor heating, swimming pools, metallic surfaces etc. For indoor and outdoor applications, on walls and floors. It is classified as C2 TE S1 adhesive, according to EN 12004 and EN 12002.
High-performance, elastic, polymer-modified adhesive for fixing all types of tiles on deformable and vibratile substrates. It is characterised by extended open time, no vertical slip and elasticity. Also suitable for fixing tiles on concrete, screeds, render, old tile layers, floors with in-floor heating, swimming pools, metallic surfaces, etc. For indoor and outdoor applications, on walls and floors. It is classified as C2 TE S2 adhesive, according to EN 12004 and EN 12002.
High-performance, fast-setting, flexible, polymer-modified tile adhesive. It is qualified as non-slip (T: slip resistant). Suitable for fixing absorptive or non-absorptive tiles on walls or floors on surfaces made of concrete, brickwork, render etc., especially when high adhesion, elasticity and resistance to moisture is required. Ideal in cases where the surfaces have to be delivered fast for use, e.g. work areas etc. For indoor and outdoor applications. It is classified as C2 FT S1 adhesive, according to EN 12004 and EN 12002.
Two-component, fast-setting, flexible tile adhesive. It is characterised by extended open time and flexibility. Suitable for fixing ceramic and porcelain tiles on concrete, screeds, render, mosaic, gypsum boards, flat roofs, floors with in-floor heating, swimming pools etc. Ideal for areas that must be ready for use within short time. For indoor and outdoor applications, on walls and floors. It is classified as C2 FE S2 adhesive, according to EN 12004 and EN 12002.
Light-weight, elastic adhesive for fixing ceramic and porcelain tiles on deformable substrates. It is characterised by extended open time, no vertical slip and high elasticity. Also suitable for fixing natural stone and decorative bricks on concrete, screeds, render etc. Ideal in case high elasticity and adhesion are required like old tile layers, gypsum boards etc. For indoor and outdoor applications, on walls and floors. It is classified as C2 TE S2 adhesive, according to EN 12004 and EN 12002.
Reply to Isomat UK: Examples of adhesives available in the Tile Adhesive and Grout Advice area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hi guys Is anyone on this forum familiar with Mapei Pro Standard tile adhesive from Tile Giant...
7K
Ian Mead
I
So after a couple of weeks trialing @ISOMAT UK products, thought it was time to give initial...
9K
I
    • Winner
ISOMAT AK 22: High-performance, flexible, polymer-modified adhesive for fixing all types of...
ISOMAT UK
I
Tile Adhesive Trending Topics
Isomat
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
