Discuss Ivory BAL Grout dried patchy in the UK Tiling Forum area at TilersForums.com.
cr0ft
Hi all,
It's been a while since I posted here as work has been busy. I'm after some advice please. Finished a bathroom for a customer a couple of weeks back. Plaster walls (left to dry around 6 months, don't ask why!!). Shower area tanked with Durabase Waterproof matting. Tubbed Mapei D2 adhesive used for small format tiles in shower area. BAL Green star used for remainder of room. BAL Ivory grout used on to grout all. Bathroom left 24 hrs between completion of fixing tiles and grouting.
Grout mixed in a very well cleaned bucket with fresh water. Mixed with a mechanical mixer, left to sit for 3 minutes then mixed again (slowly both times). All of the bathroom was grouted with one mix of grout.
The grout has dried ivory coloured in some areas and patchy darker colours in other areas. It looks awful!
The BAL rep has come out and stated that it could be the Mapai adhesive reacting with the grout. Fine, except the Mapei adhesive was only used in the shower area and the whole room is the same. They are taking a sample of the grout for analysis. He also indicated that it was surface contamination only. I used a new sealed sponge to wash the grout down and a clean towel to polish off the tiles afterwards.
Has anyone else done everything properly before and come across this? I would be most interested to know!
Thanks!
cr0ft
Hi mate. Tiles were around 160x80mm fixed in a brick bond. No bedding out otherwise I would have used cement-based and primed the wall. I hear your point about washing down but I did it the same as all my other bathrooms and they've all been fine. If anything I probably waited longer than normal before washing down because grouting them took forever due to their size!
macten
1,158
Nottingham
Almost always a water issue. Maybe tubbed stuff on tanking membrane takes a lot longer to dry.
Or maybe you left the joints wet after washing down - it's a lot cooler now and drying times get longer.
Try a bit of phosphoric acid with a white emulsifying pad (assuming tile isn't acid sensitive), do a test patch, wash off and see if it dries any better.
Next choice would be to go back in a few weeks and recolour with Fuga Fresca or similar.
cr0ft
Hi and thanks. Never used Fuga Fresca, does it work a treat for patchy grout?
Reply to Ivory BAL Grout dried patchy in the UK Tiling Forum area at TilersForums.com
    Votes: 9 6.2%
    Votes: 13 9.0%
    Votes: 10 6.9%
    Votes: 44 30.3%
    Votes: 17 11.7%
    Votes: 34 23.4%
    Votes: 3 2.1%
    Votes: 20 13.8%
    Votes: 18 12.4%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
    Votes: 4 2.8%
