Discuss Jerboa Tiles - New Floor Hollow but no tiles cracked - in the British & UK Tiling Forum area at TilersForums.com.
jinx4645
Hello and maybe someone will be able to help. We have just finished an extensive house refurbishment. The kitchen area circa 100 sq.m is tiled with 60x60 Jerboa ceramic tiles. Someone else posted historically about the colour changes to the tile picking up dirt etc. - we have the same problem (search Jerboa for other reference). Also we have a problem where the tile / flooring has failed. We have commissioned the tile association to report but they point the finger at everyone which isnt helping me resolve the issue as the client. When a few tiles have been lifted on all the tiles there is no adherence of the adhesive. The tile comes up and the adhesive is stuck cleanly to the screed but not the tile. All our key advisors suggest a failure of the tile but it seems there maybe something more fundamental going on. We have other areas to complete and are reluctant to start until we get a view on what procedure we should follow to correct the issues. The spec was as follows:
To clarify some of the key points about the construction:
• the screed was reinforced with polymer fibres
• there are movement joints around the perimeter of the area
• the screed was allowed to dry in accordance with (and longer) than
recommended by the specialist supplier and was heated and
cooled in accordance with the UFH specification
• tiles were solidly bedded (see above) but lack of adhesion was not
apparent at that time
• the tiles have darkened due to a chemical left bonded to the tile
surface once the polythene layer was removed attracting dirt of all
types and bonding the same with the tile requiring aggressive
cleaners to remove
It is clear that we have defective product on two levels - the discolouration and the method of fitting leading to the hollowness of the floor. Can anyone recommend some independent technical advisors who would be able to test all aspects of the floor, adhesive, and tile and also offer help on how we should go about resolving the problem so we can be satisfied with the product.........help!
jinx4645
The adhesive used to bed the porcelain floor tiles
was KWIK FLEX flexible rapid setting tile adhesive (photo 1), whilst the grout for the
3mm wide joints between the tiles was ARDEX-FLEX FS. The adhesive company point at the tile and possible movement of the screed.....everyone is pointing at each other.....will supply some photos....
jinx4645
See attached photos - no adhesive on tile at all....floor has adhesive stuck to it.
jinx4645
Each tile came supplied boxed and ready to fit (according to the supplier). There is a dust residue left on each tile, apparently linked to the kiln process, which is quite usual - apparently. This was not cleaned on each tile and is still present on the lifted delaminated tiles and does appear on the dry adhesive still on the floor.
Deleted member 9966
My opinion is then that the dust on the back of each tile prevented it from adhering correctly to the adhesive. I'm not a professional tiler, but having tiled floors in my own house, I have always wiped down dusty tiles and left them to dry before fixing them because that is the advice I have received from the guys on here.
Time's Ran Out
GRR has a possible answer with the dust on the back of the tile scenario but from the sample shown it is evident that the back of the tile has had no back buttering of adhesive to provide 100% solid bed fixing. The adhesive looks to have been dry/skinned by the time fixing took place and no twisting of the tile in fixing procedure to bed the tile into the adhesive.
If you had a report from the TTA what was their verdict?
jinx4645
Thx Timeless John - The verdict of the tile association was mixed - pointing at the specification of the floor screed and expansion of it and the lack of buttering - that was not seen as necessary by the tiler. They did not put too much weight on the tile or the white powder.....screed and tiler therefore at fault. The discolouration of the tile post fitting seems to have been forgotten and no one has really come up with an adequate explanation for this other than the sticky film removed before fitting has left a residue.....I will post the report edited for people and places to avoid any conflict and you can pass your own comments. We are reluctant to take up the screed and maybe adding detrimat? to the spec might deal with all the fitting issues.......
We questioned the report of the tile association only to receive a defensive response......We are no closer to having the floor that we paid for only closer to going into the tile business to sell people a product suitable for the job and learning alot along the way......
Time's Ran Out
It's a good read and IMHO as correct as it can be.
The screed and it's content will get a better opinion from Ajax (a member of the Forum) when he comes on line but I would not agree that as a tiler the back of the tiles did not need buttering.
The size of the floor would require movement joints that are not there and the fact that the Tiles - 600x600mm porcelain from China would leave me with the opinion that the polished surface has pin holes which have accepted/accentuated the colour discolouration. Did the surface of the porcelain receive any coats of sealant after grouting.
Other views to follow no doubt.
garybadger
Think the TTA have got it pretty much spot on with their conclusion there.
For me, when using larger tiles and porcelain, I always make sure, we spread the floor, and back butter every tile.
Just because the adhesive is cement based, doesn't mean its 100% not to fail.
Also looks to me as though the trowel used, is the wrong size. I'd have went for a 10 or 12mm trowel.
Sure that one looks like a wall serator. Therefore you aren't going to be bedding the tile into much adhesive at all, especially just spreading the floor.
jinx4645
Keep the comments coming all valuable stuff......what recourse do people think we have if the supplier didnt inform us about possible colour deterioration and or offer any installation advice? two issues really 1. Method of installation many views on this but what about 2. The lack of information from supplier as to recommended installation technique....misselling and or misrepresentation...Italian Porcelain v's China?!
Reply to Jerboa Tiles - New Floor Hollow but no tiles cracked - in the British & UK Tiling Forum area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
