Spare Tool
Any body fixed tiles over this...Got the spec sheet In front of me and a bit nervous of tiling on suggested method(according to spec and tech helpline) it does state that it can be tiled on but...
So basically it's a foil covered 25mm kingspan with 15mm grooves cut in for the pipes, the panels are not attached to the floor in any way and the substrate is crossing from concrete to 25mm ply screwed onto suspended joists..
The spec sheet then says lay suitable ply or Knauff Brio Board over the top again floating and tile..On the phone I was asked what's the minimum ply I'd tile on and when I said 12mm they said just overboard it with that then, when I said I'm not too happy tiling on floating ply (or any ply tbh) I suggested 10mm of fibre leveller over the lot then ditra but this was dismissed by the tech helpline, I suggested 6mm hardi fixed with rapid set then ditra but again dismissed, seems whatever over boarding is needed has to be floating and it just dosnt fill me with confidence. Tiles are 600 porc. Anyone come across this stuff before??....besides just tile the walls and walk away your thoughts please??
