Discuss jobs taking longer than expected in the British & UK Tiling Forum area at TilersForums.com.
L
LM Ceramics
am on a private job now im tiling 20 sq m2 walls and 4 floor i have been there for a week the walls were seriously out worse walls i have worked on (even worse than council properties) the customer was on a limited budget so i have tried to keep the cost down for them so i bonded the which made them a bit flatter so far i reckon i have another day on it its been a job from hell but im nearly there and it looks great so far
to be honest i thought i would have done it quicker but with all the prep work it has took longer than anticipated at one point i wanted towalk away but ive stuck at it and im starting to see the rewards
i reckon i underestimated this job alot trickier than i thought lessons to learned
L
LM Ceramics
good advice from all you guys thanks i would have thought being in the trade nearly 4 years i should be able to work out how long jobs will take put then again the firm i was working with we only tiled new houses (easy) going self employed tiling is alot different a learnining curve i think
ps anyway tiling completed and grouting tommorow and a big clean up the customer loves it which is always nice to know tiles look great great bumpy white on brickbond with a mosaic border
thanks for your advice lads
Burnsy
That's weird - just finished exactly the same job and the walls were also the worst i have ever worked on. I put my 1 metre straight edge on the wall, flat one end for 1/2 metre and at hte other end i could get my whole arm underneath it! Nightmare. The ceiling was artexed and bumps everywhere, the doorframe had dry paint all over it and was bumpy
One of the walls had tiles 1/2 way up, then a dado rail then above had been re-plastered - didn't relise this until i got to where it had been plaster and the tiles lipped out by about 10mm! showed customer and had to take tiles off, strip all plaster back to brickwork, then dot n dab plaster board. That turned out to be the only decent wall. They also had a mosaic border, but couldn't use it as the walls were so bad it would have lipped out in some places and then recessed about 5mm in others.
The floor was also bumpy and unlevel but they were on a budget and weren't prepared for the prep work. I hated this job and my motto is now the old addage
'Failing to prepare, is preparing to fail'.
Not worth the hassle trying to make good on jobs. Anyway, got my cheque this evening, going to pay it in tommorow and learn from this and recharge the batteries!
By the way, i don't think any adhesive manufacturers will gaurentee their addy if you tile on bonding, has to be a finish / top coat. I spoke to BAL Technical and they said it is a wait issue - just a thought
Reply to jobs taking longer than expected in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
  • Article
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread...
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
