• You will need to sign up (for free) to contact the member using the forum private messaging system to chat about the discontinued tiles.
I'm Looking For This Tile Johnson Floor 6x6 150x150 X8mm Beige Brown
Discuss Johnson Floor 6x6 150x150 X8mm Beige Brown in the Free Discontinued Tile Finding Service area at TilersForums.com.
John Wilkins
Near match would be ok. 1 to 10 metres required
Tile Shop
Wow..... Looks like maybe its the very very old self spacing Durastone I think, as I don't remember the Kerastar being self spaced..... its been dead for at least 18 years. Closest range now will be the Dorset Wooliscroft Stone (Also finished when Pilkingtons went down the pan in 2010.) But the range was pretty popular so after a few years when all the old stock was gone, Original style started to make them (or have them made) again.
Downside is that the size is 2mm smaller and 1mm thicker (148x148x9). So not perfect but the closest I imagine you will get now. The Dorest Quartz may also be a close colour but this has a slightly pinkier hue to it.
Versatile smooth surface Anti Slip Tile | Dorset Woolliscroft
Hope this helps
John Wilkins
Hope this helps
Paul C. Thanks for the information. Original Style have recently opened a store locally. They have samples, a near enough match, and I have now been able to order. I would not have found them with out your help. Regards John.
Reply to Johnson Floor 6x6 150x150 X8mm Beige Brown in the Free Discontinued Tile Finding Service area at TilersForums.com
Available - Porcelanosa Hampton Beige Floor Tile 22cm x 90cm (13 Boxes - 15.444 M2) Porcelanosa...
Hello, I’m looking for 10 tiles of Grespania Veneto Beige 30x60 cm ceramic tiles to make good a...
Benedikt
I'm Looking For This Tile Vitromex Sand Beige Ceramic
Hello Looking for 10 pieces of Vitromex Sand Beige 16x16 16sandbeig. Thanks!
I'm Looking For This Tile Wickes mayfield riven beige tile
I'm looking for wickes 300mm x 500mm mayfield riven beige supplied in 2016 if anybody could help...
Hello all, I’m looking for 2 maybe 3 Porcelanosa Madagascar Beige wall tiles 33.3cm x 59.2cm Can...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
