Discuss Joint size for 75x75 floor tile in the Canada Tile Advice area at TilersForums.com.
Chris Gibbs
608
North wales
Very big tiles, was thinking 5mm joint, but it actually looks huge. The tiles don't seem to be very square so I'm not sure 3mm would be enough.
Any tips for slightly out of square large tiles?
Also, thinking 10mm towel with 6mm back butter
if you look on the rear of the tile there should be an arrow. keep these all in the same direction. It sometimes helps if the tiles have a variation as they tend to be bigger or smaller on the same sides if you know what I mean. hope this helps... oh and 3mm if you can.
Reply to Joint size for 75x75 floor tile in the Canada Tile Advice area at TilersForums.com
gamer1
Uk
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
