Discuss Just a quick question..... in the British & UK Tiling Forum area at TilersForums.com.
H
Highlander
Wont go below 12mm WBP ply myself if I am using ply on a floor, a lot of guys out there willing to do it now a days. It really depends on floor movment you could use 6mm Hardibacker board for floors and would get away with single part flex adhesive and normal flexi floor grout. I have used the boards for walls and floors and laid a few hundred m2 with no problems they are good and easy to transport compared to Ply.
Gary
Highlander
wetdec
Adhesive manufacturers will advise 18, 22, 28mm ply for their flex adhesive depending on the manufacturer. If you have a standard floor board then you have around 22mm, if you ply this then you have 28mm so are in same place.
Personally.
make sure all boards are fixed sound and you domt get any movement then fix your ply to the floor. I use a tacker gun with a 16mm staple in it tacked every 6ish inches.
There is a trick to this, as you move over the floor tacking bounce your hammer over it. Hold your hammer loosley and tap it over the floor. If it bounces you need another tack there if it just thuds its cool. What it does is makes sure you dont have any voids under your ply. Try it you soon get the hang of it,
Prime your ply and off you go
Hope this helps dont be scared of it m8
tiler
Reply to Just a quick question..... in the British & UK Tiling Forum area at TilersForums.com
Hello all. I've got a question for people who know better on what to do with my floor. I thought...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
