Discuss Karl Dahm Special Maxi trowel in the UK Tiling Forum area at TilersForums.com.
jimbob
Hi
I've heard good things about these, but my question is, as a novice, which will give me better chance of getting 100% solid coverage for 450mm square floor tiles - the 12mm x 12mm maxi Karl Dahm or a standard 10mm x 20mm thick bed solid bed trowel.
My common sense tells me the latter, as the notch sizes are obviously larger, but not sure how much of an effect the little additional notches on the KD will have.
Finally, if the special 12mm x 12mm is for floors, can I assume the 7mm x 10mm KD medi trowel is for walls??
Cheers :thumbsup:
Jimbob
Reply to Karl Dahm Special Maxi trowel in the UK Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hi Guys, I've got a lot of great advice from reading through these forums but just wanted a...
Hi All, I'm on with tiling all my downstairs rooms with 60cm x 60cm High Gloss 9mm tiles. All...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
