Kera poxy grout advice needed
I have never used this type of grout before, and the 1st job I'v got with it is 170+msq anti slip porcelain. So any advice with be really appreciated.
I am planning on mixing a 1/4 of a 5kg tub at a time, enough for about 6/7msq, does this sound doable, for a first time user.
I wouldn't try mixing part amounts, its important to mix all the epoxy and hardener together. Will it be you on your own doing the grouting? If you can get a lad to help out you shouldn't have any problems. I will try to add a link to a step by step guide I put up here a while ago, bare with me...
[h=3]A Guide to Epoxy Grouting...[/h]
if you do want to mix it in batches weigh them out so that the ratio's are correct. Don't get any water in the ungrouted joints, the grout will not sick if you do.
Well I dont know what I was worried about, just followed riches guide, and not a problem. As long as you dont stop for a ***, or a brew until after the first wash. then the jobs a good un. Managing to do it in 5kgs at a time, all on me own. Thanks Rich, really good guide.
poynton phil,
poynton phil,
poynton phil,
poynton phil,
