Discuss Keraflex Maxi - Should I need batons? in the British & UK Tiling Forum area at TilersForums.com.
I
iaincameron
Hi All,
Following advice from here I have this evening started to tile after spending ages on prep! I am tiling with 600 x 300 porcelain tiles (8mm thick) onto a primed (Primer G) fresh plasterboard wall. I am using Keraflex Maxi.
The question is should I need batons with these tiles? I decided to use a baton for the first row of tiles that need to sit under a window sill, but this is three rows up. According to the Mapei sheet I should not need to use a baton, but the tiles would have slipped without it. I was planning to tile down from the first row once dry and I don't want to have to use a baton every time as it will take ages.
Could it be as simple as I have made the adhesive to runny, or with this size of tile is it not realistic to expect not to use batons?
Cheers
Iain
I
iaincameron
Thanks for the feedback. What I will do is tile from the floor up to the line of tiles I have put up so far, using spacers/wedges/cardboard etc to get the tiles at the correct level. For the other walls I'll batton at the lowest full tile, rather than half way up the wall, so I only have the cut tiles to tile without a baton. Now that the tiles are in the right place under the window sill everything else will flow from there, so it will get easier!
As an aside, I know you use Silicon at the wall joins, but do people using Silicon or grout under windowsills, from wall to ceiling and ceiling to floor (same tiles on floor, no skirtings)? I'll be using Mapei Ultracolour grout.
Cheers
Iain
Reply to Keraflex Maxi - Should I need batons? in the British & UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
