Discuss Keraquick grey cheaper than white in the Australia Tiling Forum area at TilersForums.com.
DaveyH
Hi,
I'm going to fully tile our bathroom walls using 20cm x 50cm ceramic tiles that are 7mm thick. There's 20 square meters of wall in total.
I intend using Mapei Keraquick tile adhesive.
The walls are gypsum plaster. So before tiling I will be priming the walls with Mapei Primer-g.
Now for my silly question.
While googling around for prices, I've discovered that the grey coloured Keraquick is always a few quid cheaper than white coloured Keraquick.
Why is this? Apart from the colour, what is the difference? After tiling I will be grouting with white grout. So if I was to use the cheaper grey adhesive, would it show though the white grout or something?
DaveyH
Use white, the price difference is minimal. Or even better, use mapei p9 and save yourself some money and give yourself some more working time
Thanks for replying and thanks for the tip on using mapei p9.
Why do you suggest using white adhesive, is it because grey could possibly show through the white grout?
I just can't get my head around why they Mapei bother to make grey and white tile adhesive, because at the end of the day, it's all hidden behind the tiles and the grout. :confused:
Mr Tiler
Why do you suggest to use white adhesive, is it because the grey could possibly show through the white grout?
that's the reason mate it could show through the joint and your grout could be patchy, grey is for darker tiles/ joints... also be sure you are using the recommended mixture of primer/water.
also when spreading your adhesive you want to use the flat side of the trowel to get a good 'key' with the substrate and make sure the wall is as flat as possible before tiling.
Reply to Keraquick grey cheaper than white in the Australia Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Hi after some advice . Just finished the shower cubicle , used a Mapei white grout and the grout...
    Votes: 5 4.5%
    Votes: 8 7.2%
    Votes: 7 6.3%
    Votes: 32 28.8%
    Votes: 14 12.6%
    Votes: 28 25.2%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.1%
    Votes: 18 16.2%
    Votes: 13 11.7%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
