Discuss Kerdi coll alternative in the Canada Tile Advice area at TilersForums.com.
As someone said to me recently, if you were to cut @impish in half it would say Schluter all the way thro, :D so if there is an alternative, he would be the one that would probably know.
I wouldn't hold your breath tho! :)
I would have thought tho if you stuck the actual membrane with regular adhesive but taped the joints with kerdi Keba and kerdi koll, it'd have the same result.
But that's only a guess.
Lexter
London
Thanks for responses.
The reason why I've have to cover the plasterboard is due to it being an insulated foam backed board. The showers are outside but under some arches. Had no choice as it had 100mm insul all built in.
I will go for the ardex wpc as your right this would save loads.
Thanks for quick replies
One Day
Why are you fixing a waterproof membrane with waterproof adhesive?
Schluter over-kill at work again!?
I would fix using a standard adhesive - as they do in the States.
Unless you're totally in need of a guarantee, then you'd have to use kerdi-coll (slow-set).
Personally, I'd always lap my corners and joints with kerdi-fix these days. Far easier to do and still effective - although I know Schluter would say "not the correct way".
Ardex WPC would work, but why bother? Either use the full monty or use standard adhesive imo.
Reply to Kerdi coll alternative in the Canada Tile Advice area at TilersForums.com
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
  • Sticky
London
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
