Kitchen Floor Advice
davereid
Hi
Thanks to all who provided advice on my bathroom project 3 years ago, tiling both the shower area, walls and floor. I'm pleased to say all tiles intact and no cracked grout.... thank you.
Now onto my next project, the kitchen. Looking to tile the floor with 33cm by 33cm porcelain tiles.
The kitchen is downstairs and approx 5m by 3m. One end of the room is a concrete subfloor which extends into the room approx 1.2m. The other side of the roo the concrete is an L shape. The end of the L shape will be covered by a run of base units but the top of the L and side of the L will not be covered. In between the two areas of concrete is 15cm wide floorboards which are bowed in the middle.
Im thinking of removing floorboards and replacing with 25mm wbp ply. Clearly I will need expansion joints exactly where the concrete meets the ply. I've calculated that to get expansion joints in the correct place I will need to remove 8cm width from one edge of concrete. I'm hoping the plywood could bridge this gap. I would then bring the remaining concrete up to level with SBR/Addy slurry and SLC.
1. Firstly is there such a thing as some floors that can never be tiled?
2. Does it sound like a workable plan or not?
3. If its workable, would others use ditra over the whole floor?
4. Is there anyway it could be done as brickwork or again are there some floors that can only ever be done as non-brickwork pattern?
Thanks for reading this far! Any thoughts greatly appreciated.
Cheers
Dave
yes here are my thoughts
why don't you get a professional tiler to come in and have a look for you he will properly tell you everything you need to no
Ask him to give you a quote
You may be surprised and you will properly get a much better job done. I presume you are not a tiler and just a d.i.yer
davereid,
swanman,
davereid,
swanman,
