Discuss kitchen floor prep in the British & UK Tiling Forum area at TilersForums.com.
N
negsy26
hi guys, would love some advice on a kitchen floor.said floor is 30msq and half of it has floor boards down the other half is concrete! ceramic tiles are going down probably 300mmx300mmx10mm. devimat going down too. customer wants it done right but with minimum floor raise as possible.existing wooden floor is in good condition and fairly stable.i was going to screw down existing floor to really make sure of no movement then put down 6mm backerboard over the whole area using spf ( dont fancy screwing through the concrete !) devimat on top the backerboard then spf & tile, grout with flexi. what do you think?
N
negsy26
i think im going to do this - fix down existing ' planks ' securely,then, 10mm backerboard fixed down with ardex 7001 (and screwed on wooden part of exsisting ) then the devimat then latex over with arditex na, finally a spf to fix the tiles with and a flexi grout !! i think that should do it !! what ya reckon ?!!
Reply to kitchen floor prep in the British & UK Tiling Forum area at TilersForums.com
kitchen floor prep
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
