F
frogeye
Hi All
Hope everyone had a merry christmas and enjoy a happy new year.
I have just measured up a little kitchen floor job, wierd shaped but do-able.
The floor is a mix to say the least. Modern lino type stuff on top off older lino stuck down with what looks like a black mastic (thin coat) then there appears to be a few thermo plastic tiles for good measure. Once removed the floor should be relatively level. 3 doors in, I from carpet, 1 to concrete in a cupboard so can incorporate but 3rd to continuation of lino floor. Fingers crossed I dont have to level as it will leave two awkward door thresholds to sort.
So my main question is floor prep. Can I use the bal sbr (?) to prime once I have got up most of the previous adhesive - a black stuff? A Bal flexible rapidset for tiles and as the customer has picked the worlds most wavy edged tiles - a flexible wide grout - no problems with grout lines then ho ho? Any suggestions would be appreciated.
Also the tiles are Hispania Ceramica - single fired floor tiles made in Spain - not a problem I hope? But at least I can select my adhesive and grout.
Threshold bars? Which is best to keep the obvious rise down to a sensible size? They are both a bit old and fragile so no trip hazards wanted.
This is my first paying outside the family and friends job - a straight forward square pattern, so no pressure
frogeye
frogeye
