Discuss Kitchen splash back on the diamond in the British & UK Tiling Forum area at TilersForums.com.
Jeffinoz
Hi Guy's
Doing a kitchen splash back on the diamond with 100x100 white ceramics would i just start the bottom row a half tile? and is there anything i have to look out for ? This is a 4.5 m2 no windows 2 sockets also grouting about 5 m2 of tile that have just been done by another tiler he is in hospital for a long time also about 2.5 m2 of skirting how much would you charge for this i have quoted $600 about £250 your money no mats.
Jeff
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
If you are starting off with half a tile from the work-surface then make sure you are starting at the lowest point so that you are nipping the tiles on the higher point to keep the setout level else starting off at the higher end of the worktop would cause you to have a gap at the lowest to stay level or you'd follow the drop/fall and wouldn't be level.
Not too sure on charges. If it will take you a day then it sounds like you're on a fair wage charging what you quoted so i'd stick with that.
I'm sure the others will give their view in a bit, most are at work at the moment. :)
Reply to Kitchen splash back on the diamond in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
https://www.amazon.co.uk/Leveling-System-300pcs-Spacer-Resuable/dp/B08P54N6F1/?_encoding=UTF8&pd_...
Hi all, I was hoping I could get a little advice. Currently doing a bit of tiling in the...
Dumbo
Hello all, I have a job this week doing a kitchen splash back and window reveal. The wall...
6K
Hi folks, new to the forum and I'm a DIY novice with no tiling experience to speak of. Been...
5K
WetSaw
I know from reading old posts on here this can be a sensitive subject - but I have some...
21K
Bespoke Tiling
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
