Discuss kitchen splashback in the British & UK Tiling Forum area at TilersForums.com.
jimbob
Hi,
Will soon be starting to tile kitchen splashbacks and have some questions.....
There is a gap between kitchen wall units and stainless steel cooker splashback. Should I start tiling level with the wall units and leave a gap still, or should I tile from stainless steel splashback itself, and if so how high should I take the tiles between the wall unit and the cooker splashback?
Also a few other things I wanted to check before I start....
1. Begin with full tile right above worktops, unless there is a stupidly narrow cut underneath wall unit, in which case start off with a cut tile above the worktop so there is a decent cut under the wall units.
2. Start with a full tile next to cooker splashback unless there is a stupid cut at the wall, in which case start with cut tile.
3. Silicon gap between tiles at corner of wall, and between tile and worktops and between tile and underside of wall units
4. I have ordered keraflex maxi adhesive in the grey, and my grout is going to be white - it has suddenly struck me the grey adhesive may show through the white grout. Am I ok with grey adhesive or should I order white to avoid the problem?
5. Tiles are 10cm square and walls are pretty flat, but used to have old kitchen tiles on, so not smooth as a baby's bottom - was intending on using a 6mm or 8mm trowel. Which one would be best?
Cheers :thumbsup:
Jimbob
jimbob
Just attaching some pics of gap between wall units and cooker splashback. (Packets of poppadums shown on first pic will be removed prior to tiling)
david campbell
Hi,
Cheers :thumbsup:
Jimbob
1.yes begin with full tile,can the tiles not go behind the units there's usually a small gap
2.measure out the wall using tile sizes,you will want to avoid small cuts at the cooker and the corner,also avoiding akward cuts at the sockets
3.yes,Silicon spot on
4.use white adhesive
5.8mm,however,depending how bad the walls are and if you are struggling to get your tiles even then maybe a bigger notch will be needed
can i ahve the pompadomms and some spiced onions if you have any......lol
jimbob
Is that Sainsbury's taste the difference pasta in the pic mate, mmmmmmmm
No, it's Tesco mini poppadoms!
David - thanks for advice - you can have the spiced onions but unfortunately the poppadoms have all but gone, along with half a jar of lime pickle and some spicy mango chutney....mmmmmmmm :drool5:
Reply to kitchen splashback in the British & UK Tiling Forum area at TilersForums.com
Hey everyone. Hope you are well. I want to learn how to tile and do a fairly basic bit of...
kitchen splashback
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
